ETON MGS 180 3 way Component
ICE -In Car Entertainment
hois
MGS 180
http://www.kklau.com.my/images/mgs180top_award.jpg
http://thumbnail.image.rakuten.co.jp/@0_mall/auc-fineproject/cabinet/audio2/mgs-180-3way.jpg
The Eton MGS ensures perfection even for spoiled ears and sets new benchmarks for high-end loudspeaker systems. The central element of the whole system is the 28mm tweeter, which impresses through the use of innovative materials. The Magnesium-membrane, light and at the same time extremely stiff, ceramic coated, guarantees excellent acoustics. The midrange woofer provides the Eton-typical Hexacone membrane with a Nomex-comb between two airproof Kevlar layers.
Technical Data (midrange) Symbol MGS 180
Outer Diameter 165mm
Cut-out Diameter 143mm
Mounting Depth 66mm
Nominal impedance Zn 4 Ω
DC resistance Re 3,3 Ω
Characteristic sound pressure level 1W / 1m 89dB SPL
Rated power 70W/100W
Resonance frequency 1 Watt fr 60 Hz
Effective piston area SD 137 cm2
Suspension compliance CMS 0,21 mm/N
Mechanical Q factor QMS 4,46
Electrical Q factor QES 0,54
Total Q factor QTS 0,48
Equivalent air volume of suspension VAS 5,5 dm3
Mech. resistance RMS 2,48 kg/s
Total moving mass (including air mass) MMD 25,3 g
Voice coil diameter 32 mm
Voice coil carrier Aluminium
Wrapping amplitude 155 mm
Nr. of layers 1
Voice coil inductance Le 53 mH
Magnetic inductance B 10 Tesla
Power factor BL x I 7 Tm
Height of pole 8 mm
Magnetic ring diameter 102 mm
Magnetic ring height 22 mm
Mass of speaker 1,95 kg
RM 4000 013-3955166
