[WTS] DLS Iridium 6.2i Component Set 2-way
ICE -In Car Entertainment
acidcoller
Item(s):
Ultimate Iridium 6.2i is a 16,5 cm (6,5") 2-way system. The 6,5" driver uses a cone made of non-press paper.
- Improved model with die cast basket.
- Hybrid ferrite/neodymium magnet system.
- Three inch voice coil.
- Filter boxes with selectable tweeter level.
- 28 mm silk dome tweeter Iridium1i.
- Grilles are included.
Iridium 6.2 was awarded as "EUROPEAN MOBILE LOUDSPEAKER OF THE YEAR 2004-2005.
Read the jurys motivation: This 6,5" component system is one of the best ever from the Swedish competition-oriented brand. The DLS Iridium 6.2 passes comfortably that border which divides the technically perfect but average sounding equipment from the true audiophile products. The parts used in this system are an excellent combination of proven techniques and up-to-date innovative solutions. The cone of the woofer is made of non-pressed paper, which has been among the best for decades, and this complemented by the hybrid ferrite/neodymium magnet and aluminium voice coil. The switchable crossover contains foil coils that are exceptional in the field of car audio. DLS has successfully turned it´s technical knowledge into musical notes of the highest quality
Package :
Ultimate Irridium 6.2i 2 way component system 6.5inch
Aluminium Connector speaker ( Best For Solid Sound)
Aluminium Tweeter pod
Specifications
Woofer size - 16,5 cm (6,5")
Tweeter IR1i - 28 mm (1,1") tweeter in metal housing
Power handling capacity 100 W RMS / 160 W max
Impedance - 4 ohm
Frequency range - 50 - 25.000 Hz
Sensitivity - 91 dB (1W/1m)
Crossover - Filter box with 6/12 dB slope (LP/HP)
Crossover point (Hz) - 3800 Hz
Size of filter box - 145 x 85 x 45 mm ( 5,71 x 3,35 x 1,77")
Outer diameter of woofer - 165 mm (6,5")
Magnet size - 85 mm (3,35") Hybride ferrite/neodymium
Mounting depth - 65 mm ( 2,56")
Mounting hole - 140 mm (5,51")
Price: RM 1288.00 :driver: NOW SOLD
Dealing method: COD or Post via Courier Service add RM 35.00
Location of seller: Pandan Indah / TESCO Ampang
Contact method/details: PM/SMS/CALL
Age of item:
Excellent Condition. Best for vocal and dynamic sound. Before this running with STEG QM SERIES. Used around 1-2 years
Picture:
Reference's:
http://www.dls.se/en/car/prod.html?produkt=en_80
