VISATON High-End DVC Subwoofer from Germany
ICE -In Car Entertainment
lmh77
20 cm (8") High-End woofer with black glass fibre http://www.visaton.com/en/lexikon/C/158.html, solid aluminium die-cast basket and elastic rubber http://www.visaton.com/en/lexikon/S/130.html. Designed for multi-purpose applications due to 2 x 4 ohms double voice-coil, with excellent properties as 8 ohms drivers in series configuration. The long stroke voice-coil in conjunction with the extended rear pole plate, the vented damper, the vented http://www.visaton.com/en/lexikon/M/82.html and the capton voice-coil carrier guarantees long strokes and highest power handling.
Please Contact me at 012-9142998
COD area: PJ, Subang, Puchong, USJ/Sunway
Technical Data: Rated power 120 W Maximum power 180 W Nominal impedance Z (1) 4 Ohm
(2) 8 Ohm
(3) 2 Ohm Frequency response fu–8000 Hz (fu: Lower cut-off frequency depending on cabinet) . Mean sound pressure level (1) 85 dB (1 W/1 m)
(2) 88 dB (1 W/1 m)
(3) 88 dB (1 W/1 m) Maximum cone displacement +/−10 mm Resonance frequency fs (1) 34 Hz
(2) 30 Hz
(3) 35 Hz Magnetic induction 1,3 T Magnetic flux 930 µWb Height of front pole-plate 6 mm Voice coil diameter 38 mm Height of winding 18 mm Cutout diameter 190 mm Net weight 2,5 kg D.C. resistance Rdc (1) 2,9 Ohm
(2) 5,8 Ohm
(3) 1,4 Ohm Mechanical Q factor Qms (1) 4,51
(2) 4,12
(3) 4,33 Electrical Q factor Qes (1) 0,93
(2) 0,37
(3) 0,44 Total Q factor Qts (1) 0,77
(2) 0,34
(3) 0,39 Equivalent volume Vas (1) 62 l
(2) 68 l
(3) 57 l Effective piston area Sd 214 cm² Dynamically moved mass Mms 25 g Force factor Bxl (1) 4,6 Tm
(2) 9,2 Tm
(3) 4,6 Tm Inductance of the voice coil L (1) 0,4 mH
(2) 1,1 mH
(3) 0,3 mH
http://www.visaton.com/en/chassis_zubehoer/tiefton/gf200_2x4.html
Hi, Mr.Wilm,
Please check yr PM.
TQ
New stock with Price Revised:
RM500
Bump:
Bump:
Price Reduced,
Can Nego.
TQ.
---------- Post added at 10:48 AM ---------- Previous post was at 10:44 AM ----------
10" also available ;
10" Available Now
12" Coming Soon!
Sorry ,
Price Increased!
RM550
TQ
Very Good SQ subwoofer Bass for small car like Myvi, Kenari & Viva!
TQ.
:driver:
