Rainbow SL-C6.3 3 ways comp speaker
ICE -In Car Entertainment
chuppingaudio
Johor Bahru
Rainbow SL-C6.3 PRO
SOUND LINE PRO
3 ways comp speaker
Features & Specs
All components are state of the art and were with the latest software and hardware for membranes and magnetic drive developed. To be the sound of aspiration, the Sound Line Component systems equipped with a 25 mm silk dome tweeter. Just to reproduce natural sounds of this system with ease. Here, the long-stroke woofer works with aluminum composite membrane for a rich and powerful bass. Coupled with the well-positioned tweeter and a high-quality controlled crossover, install acoustic peaks Technology from Germany.
The Tweeter
25 mm silk dome tweeter to 30 kHz
Neoprene surround for controlled motions
Vented voice coil former with V2A-strands
Extremely powerful high-temperature neodymium magnet
Ferrofluid voice coil cooling
The Crossover
Low-impedance and low-distortion foil capacitors for brilliant treble
4 times the gain reduction in combination with HALO-PTC system for the tweeter
Switching of the crossover frequency of the tweeter
The Woofer
Low resonance aluminum Druckgußkorb with large air flow
Aluminum paper-composite membrane for extreme depth
Extremely flexible surface-refined lead wires, which in the centering is woven
High temperature, vented 38 mm stainless steel
Voice coil former for high maximum power
Very low distortion and impedance magnetic field linearisation
Specifications
Peak power / pulse load: 180 watts
Power rating / nominal load: 120 watts
Minimum amplifier power: 75 Watt
Sensitivity / Efficiency: 90 dB 1W/1m
Transmission range: 45-30000 Hz
Impedance / Impedance: 4 ohms...
Read more [+]
BINB
Brand NEW
Guarantee working normally
Working good condition
Check out more setting/functional website
Rainbow audio usa
To ensure that item are working, myself test it before
shipping/courier/posting.
Click at my store Mudah @chuppingaudio & fb @ck chupping for other goods ie.DVD, Power amp, Single disc, woofer, Speakers...etc
Pls cal/sms/WhatsApp/Viber to deal 019-7304525
Price: $1400
