[DIY] Oil catch tank
Normally is the one with high vacuum, if not sure when go for car servicing just ask the car mechanic. They were tell you.
Hi all,
Very good tread.., I've been reading thru' out everything about OCT Diy but unfortunately there is none showing on how exactly to install it on a kancil 660 the right way and to the right part/s.., as most of the photos doesn't show the other end of it.
We know kancil...there are lots of differences compared to other cars. I would really appreciate if any of the Sifus here could shed some light/s on showing me how to implement@fix@install this OCT thing on my wife's kancil. I really did searched around the net..but what i found are confusing...as some says here...and some says there.. It confused me.
Please help me to install it the right way... or at leased point me to the right link with indication/s of the parts as I'm still learning.
Do correct me if I'm wrong...
1 of the hose should go to what we call "Rocker" the cover where the engine oil cap resides where there's an "L" shape under the air filter base to 1 of the OCT outlet... I need to know where to fix the 2nd hose. Please help..My thanks to all of you in advance and my appreciation for the assistance.
Thank you.
Hi all,
Thank you.
Take some close up pics and I'll assist where I can
My greetings to all members of the forum...and to you Sir.., Regarding the oct I decided to sketch a diagram of my kancil 660’s connections as the engine is bloody dirty to be viewed at… Lol..! I bet you guys would laughs at it..lol..! But I believed you sifus are familiar with it as well. Kindly advice and help me.
Today I did some diys I picked up while surfin’ the net for the past 1 week.. I replaced the distributor “O” ring, the Petrol Filter, Fake alarm LED as mine doesn't have one.. and 2 points Grounding instead of 5 with 40Amp domestic cable which have been lying in my store for quite sometimes..Lol.. Hope to continue with the rest within this weekend… then would start doing the rewiring of kancil 850 Panel Meter (I got it free)..Without the connectors for the slots and worst still is the plastic circuit had badly damaged. I would install White LEDs instead of T10…should be awesome right.. I’m still searching for the schematic as I’m not familiar with automobile color code and circuit/s, like the “sender” for fuel and temperature gauge. I wanna install and replace it into my kancil which doesn’t have the Tacho meter. I would be very glad and highly appreciate if friends and members here would be kind enough to point /assists me to any link they’re aware off… I thanked everyone here in advance particularly to Izso for every efforts and assistance given.
Thank you.
Ah.. you don't circulate the pcv outlet like that. Seal off point #1 and vent to atmosphere point #2 using one of those mini mushroom airfilters (you can get for RM20 bucks at brothers).
Lol...lol..! Thank you very much Sir for your prompt reply... the funny thing was...That was what exactly I did previously except that... I didn't do the #1 and #2 as per your instruction...lol..!
I will try it tomorrow when I'm free... So, that's how it should look right (in the attachment).
I really..really..thanked you for your kindness and generosity in helping me.
God bless you, your family and your generations to come.
Thank you very much.
Wah.. very polite, rare forummer you are! But no need for such formalities, if I didn't help you someone else would have. Just a matter of time.
As for the #1 in your new diagram, is the outlet coming from the engine block or the rocker cover? Because if i'm not mistaken there shouldn't be any outlets coming from the block itself.
I guess that's normal kot.. you appreciates and thanked the person that helps you and pray for God's blessing towards them... Anyway, the #1 came from #2..the engine block as per the diagram. Is there a problem..coz' I've done the modification d...lol.. and so far there's no probs..yet..lol..!
Thank you Sir.
Thank you Sir.
If the diagram is right, it's most likely the breather outlet, which circulates back into the manifold. So yes, the breather there should be correct.
Monitor your idling, but i'm not sure how the idling is affected with this sort of setup on a carbie. For EFI it'll have idling issues if incorrectly setup.
Hi again.., Is #2 is what you call breather..? There is another one.., it's from the carb but the hose is attached to a condenser and another hose to the other end of the condenser which laid loose down just like that without any attachment.
I now remembered.., b4 i came for help here, I did ask around few mechanics and 2 of them had instructed me to connect it to #1 and #2...and after doing that there were nothing came in thru' the OCT unit and I tot maybe they were wrong as my engine bay was filled wt engine oil. I did some searching and found out that maybe it's the distributor "O" ring is the culprit for splashing the engine oil under the distributor... and so I replaced it... And yes the "O" ring was harden d. With the setting instructed by you.. my dashboard shakes... unless if I tuned(I'm good with it..lol..!) it higher. anyway, is there any other suggestion..? or are you having doubt with the setting..? Me got no prob... No worries, I can keep on testing it for few more days while waiting for your confirmation. Thanks a million.
p/s: About the tuning..learned a lot thru' observations by mechanics after they put holes on my wallet..!
To be honest I'm not a carbie expert, but my understand of engines is the OCT is best placed at the PCV side. If your car is idling really harshly, suggest you try asking around. And when you said you need to adjust it higher, adjust what exactly? The ignition timing? If it's around 750 / 850 rpm at idle it's fine la. Is the idle stable? Or do you get a lot of stuttering?
Me no expert too.., but till now everything seems to be ok..! About the timing thing.., the car doesn't have a tacho gauge.. I did my timing by pulling out the two hoses from the condenser the one attached to the distributor.., adjust the distributor until the engine doesn't vibrates then tighten it.. then put back the to hoses... and if the idling is too high or to low, I'll adjust the screw (as big as 5sen) behind the carb..that's it. So the fact is.. I don't really know what's the rpm would be.. That is also, as to why i wanted to diy and do the rewiring of the 850 Meter Panel thru' direct wiring which means.., I'll get rid of the damaged circuit behind the Panel Meter.. and for that reason I need to get in hand of the schematic, as I saw there's some kinda Diode or maybe a bridge rectifier soldered onto the circuit...Anyway, If it's too hard to obtain the schematic.., then i have to opt for an external tacho meter.
As for now I think evthing is smooth and fine..no worries..it's just another gadget thingy..if worst comes to worst...I'll just get rid off it..ha..ha..
Thanking you for all the help and concern.
nassershah, interesting, with the diagrams and all..good work..
u mentioned the dashboard shakes with the current setup, i.e #3 to line 1 and #4 to line 2, #1 plugged and #2 with mini filter... what if you connect back #1 to #2 with normal tube and maintain the OCT setup, will the dashboard shake? just give it a try to see...
I've been looking at your pictures, and looking at these diagrams:
http://www.motoiq.com/magazine_articles/id/2032/pageid/3345/crankcase-ventilation-explained--na-edition.aspx
correct me if I am wrong.
The first set of pictures you installed an Oil Catch from valve cover to intake (before throttle body).
The second set of pictures you installed an Oil Catch from PCV valve to intake manifold.
Won't it be ideal to do both? Instead of one over the other (for a N/A car). Would be bad for a turbocharged car to do valve cover to intake without a 1 way check valve.
Greetings to all Sirs..,
I did that b4 came for help here, I undo it back as I tot it was the setting that makes my engine bay spilled Eng Oil. Haven't try yet since replacing the new Distributor "O" ring.. I'll give it a shot 2morrow and will come back with the out come of it.
Thank you Sir.
---------- Post added at 05:59 PM ---------- 6 hour anti-bump limit - Previous post was at 05:34 PM ----------
My greets to you Sir,
The 1st pic was the original setup and the 2nd pic was as instructed/advice by Izso.
Regarding your suggestion..."Won't it be ideal to do both?" Could you kindly elaborate further please..
Does it means..I need another unit of the OCT..?
Regarding the terms.., Please correct me if I'm wrong.. The "L" shape on the Rocker Valve Cover is what I call PCV..lol.. and from the "L" thingy to the other end..usually would be the PCV Valve. Maybe I got confused wt the terms.. but I'm very sure my kancil doesn't have that PCV Valve with the Ball Bearing in it. What I did was..a straight forward connection on the same spot between #3 and #4 by cutting in the middle of the hose and attached it to the OCT line #1 and #2. I'd be glad and appreciate if you could correct me the exact term/s of it.. it was my mistake..sorry for the confusion..lol..as I'm no expert in automobile and most of the terms I picked ups while searching for the solution on the OCT.. and would be glad to have more suggestion from all the sifus here.
My thanks and appreciation to all of you guys for the efforts, advice and assistance.
Thank you.
sorry to confuse you, by pictures I was referring to izso's pictures. :) was hoping he can chime in. I'm not an expert in the issue.
Ha..I did as you've asked me to try...Yes.., It did stopped the vibration as a matter of fact..the engine doesn't seem dragging anymore...but still not really sure..as I've just installed VS made in sendiri..plus all the Grounding Points about 6-7 of them..lol.. and yes, my AC feels cooler now. thinking of diy a bigger capacity but not really sure what's the whole value of the caps specks and arrangement... any idea Sir..? Anyway thanks for the tips and your prompt reply..gotta go..sending my kids tuition..! I'll come back later to check others reply.
Thank you Sir.
P/s: God..! I just saw the LINK on your post...THANK YOU VERY MUCH..I'll study all the diagrams..! I notice most of the Valve Cover had 2 outlet compared to mine..only 1. I guess I should try install the OCT in between of #1 and #3 according to my first diagram...What say you..? I shall try on the 2nd Diagram of your Link which is quite similar to mine... only problems is...Mine...there are lots of tubes with "T" connections b4 it goes to the throttle body...lol..It's really headache...
Thanks again Sir.
izso..
how to install OCT for 6a12tt..need yr guidance....
