- Joined
- Apr 17, 2006
- Messages
- 76
- Points
- 1,508
Hello ZTH,
http://auto.meifung.com/images/magneticdrainplug.jpg
Description: Increase your engine lifespan with the MFactory Magnetic Drain Plugs. By removing metal shavings from your oil, this will prevent premature damage and increase the life of your engine. You will notice a smoother running engine and significantly cleaner oil between changes.
Do not let your next oil change go by without installing our Magnetic Drain Plugs. Our plugs replaces your stock OEM drain plug with hassle free installation. Don't rely on your oil filter to catch damaging particles in your oil - Your oil filter Will Not save your engine from metal shavings.
Our Magnetic Drain Plugs come with a crush proof aluminium gasket to stop leaks and utilises a neo-dymium magnet which will not rust. Beware of cheap plugs on the market with a weak magnet.
Ask yourself this: What is the point of having a weak magnetic plug to catch metal shavings when the oil in your Oil Pan will literally just wash the shavings away!
Be aware of this, because when you change your oil, other plugs on the market will give you a false indication (i.e no metal shavings) indicating your engine is fine when the story could be altogether different. Don't waste your money on a weak magnetic plug.
The MFactory Magnetic Drain Plug really is Cheap Insurance.
The image above shows our magnetic drain plug lifting an old Cam Gear, a rear camber arm (Weighing over 1.3kg! You would be hard pushed to find a competing plug able to lift even half that weight!) and 2 plugs attracted to each other through a solid wood shelf.
Features:
- Made of Aluminium, not steel
- Neo-Dymium Magnet that Will Not Rust
- Tested to hold over 1.3kg!
- Extremely cheap insurance for your engine
Fitments available for:
- Honda
- Nissan
- Mazda
- Mitsubishi
- Toyota
- Subaru
- Lexus
- Ford
- GM/Vauxhall/Opel
Price: US$13 including shipping for either Sump or Tranny Plug.
SPECIAL OFFER: Order BOTH the Sump and Tranny Plug for Only US$20 Shipped! :thumbup:
To place an order, you can do so directly via our online store: http://www.mfactoryhk.com
Payments accept in USD via PayPal (all major creditcards accepted)
Features:
- Honda
- Nissan
- Mazda
- Mitsubishi
- Toyota
- Subaru
- Lexus
- Ford
- GM/Vauxhall/Opel
