MSD Plug Wires for Distributor Cars
stupidcar
5,000 RPM
We are the authorized dealer of MSD Ignition, Perma Cool and TransGo.
We are offering MSD Spark Plug wires for any cars that run on spark plug wires like 4G1, 4AGE, 13B(RX8) just to name a few.
We dare to say MSD Plug Wires are one of the best in the world, if not, the best in the world with only 50ohm of resistance a foot.
"The MSD 8.5mm Super Conductor Wire is "the" performance wire.Engineered from the inside out, the 8.5 offers everything you have everwanted in a wire; incredibly low resistance without electronic interference! In a single 12 inch length of Super Conductor Wire there is only 40 - 50 ohms of resistance! That is the lowest resistance of any helically wound wire. To accomplish this, we use a copper alloy conductor due to it's great voltage carrying capabilities. The low resistance results in less loss in spark energy so more reaches the spark plug. The conductor is wound extremely tight around a special center core. So tight in fact, that there is over 40 feet of conductor wrapped into a single foot of plug wire. This winding procedure, combined with a ferro-magnetic impregnated center core, produces an extremely effective Electro Magnetic Interference (EMI) "choke". This choke, or suppression capability, keeps the EMI inside the wire where it cannot interfere with other electronics on your vehicle. The outer sleeve that surrounds the conductor assembly is just as impressive. A proprietary blend of silicone and synthetic material produce a sleeve that is highly resistant to high heat as well as abrasion and tears."
http://www.tunersandtoys.com/MSD-Ignition/MSD-Spark-Plug-Wires/MSD-Plug-Wires
