WTS: RM50 - Magnetic Drain Plug for ALL cars
hypermount
MELAKA
WTS: RM50 - Magnetic Drain Plug for ALL cars & oil filter magnet
Item(s): Magnetic Drain Plug suitable for oil sump and gearbox
Package includes: Magnetic Drain Plug with washer
Price: RM50 + 6 (postage & handling) via Poslaju, needs only 1 day to arrive
Dealing method: Maybank2u and other Online bankings
Contact method/details:PM
Age of item:NEW
Most of our engine parts still contain ferrous materials. You'll be surprised to see the amount of metal shavings attracted to the magnet. This drain llug will attract small metal particles that are floating within the engineoil and prevent them from causing harmful damages. It will help to keep the oil clean and prolong the life of the engine.
Suitable for:
All Protons (with Campro and Mitsu engines), Audi (pls state ur model), Chevrolet (Daewoo), Ford (pls state ur model), Holden, Honda, Hyundai, Isuzu, Jaguar V8, Jeep (pls state ur model), Kia, Land Rover, Mazda, Mercedes (pls state ur model), Mini Cooper, Mitsubishi, Saab, Volkswagen (pls state ur model), BMW, Daihatsu (Perodua), Lexus, Nissan, Toyota.
From Wikipedia:
Why we can't use other magnets?!
Neodymium magnets are very strong relative to their mass, but are also mechanically fragile. Like other ferromagnetic materials, neodymium magnets lose their magnetism above a temperature known as the Curie point. But the most powerful grades lose their magnetism at a relatively low temperature: 80 degrees Celsius (176 degrees Fahrenheit) and above. High-temperature grades will operate at up to 200 and even 230°C.
The grade of the neodymium magnet used on the tip is N42SH which is very strong. The higher the number, the stronger the pulling power of the magnet. Most other neodymium magnets have only NXX without the SH rating. SH stands for Super high temperature and that means it can heated up to 150°C without losing any magnetic power. Normal neo magnets (like our hard disk magnet) will begin to lose their magnetism at 80°C which is our operating engine oil temperature.
Item(s): High temperature graded Neodymium disc magnet - grade N42SH - suitable for oil filter and universal application.
Price: RM30 per piece + 6 shipping, discount will be given for multiple items
Dealing method: Maybank2u and others, poslaju
Contact method/details: PM
Age of item: New
Size: similar to 10 sen coin, nearly 1''. About quarter inch thick.
Materials: Triple plated with Zink Neodymium magnet.
Strength : Pulling power is more than 13kg rated!
Special characteristic : Can be heated up to 150°C without losing its magnetism due to SH rating. Much Stronger than FilterDot (but FilterDot's magnet is encased in metal casing and resin for protection). Had a hard time to separate these magnets stacking up together (nearly got panic hehe) and be Warned!
, it can snap and injure your fingers. Buy more than 1 to see and experience yourself! Separators will be provided for multiple items purchase. Satisfaction guaranteed!!
From Wikipedia:
Why can't we use other magnets?!
The grade of the neodymium magnet is N42SH which is very strong. The higher the number, the stronger the pulling power of the magnet. Most other neodymium magnets have only NXX without the SH rating. SH stands for Super High temperature and that means it can be heated up to 150°C without losing any magnetic power. Normal neo magnets (like our hard disk magnet) will begin to lose their magnetism at 80°C which is our operating engine oil temperature.
Any engine will produce some sun-micronic metal shavings or particulates.
Sub-micronic finely distributed iron particles act as a co-catalysts in oxidation of petroleum molecules.
Removal of these fine iron particles from oil circulation, reduces the oxidation rate and therefore extends lubricant service life and reduce the engine's wear and tear rate.
[youtube]hMy9WihYHPw[/youtube]
Bro do u have a contact no. need to clarify some info.
pls call me 0184657157
bro can COD or not + pm me best price 4 the Drain Plug & disc magnet 4 daihatsu
do you have magnetic drain plug for toyota 1jz manual gearbox and engine?
hypermount, the High temperature graded Neodymium disc magnet use 1pcs is already enough?
is this magnetic drain plug can install in mitsubishi 4G92 gearbox? Can be cash on delivery?
