Follow the arrow. PCV to filter in then filter out to inlet manifold.....Eyh, shit, I just realised I connected wrongly. Lol.
Are you going to use a proper OCT can or one of those fuel filters?Can I get a clearer picture on MyVI OCT implementation? Noob here and very interested with installing OCT on my 2006 1.3 MyVi. Very sorry to bro Izso as I don't see the host clear enough going from where to where and which one is intake and outtake.
i don't recommend what I did with the fuel filter. I found out later that it deformed and ended up clogging the inlet. It made it a lot worse. Better to use a proper OCT canister.Have not decided yet.
Is there a difference? Probably going to those ready made cans where some have 2 ports and some 3 ports.
Vacuum is too strong. If the filter is always dry then its ok. Once the filter is wet with oil (which it will) this will cause it harder to suck thru the filter and the air will pressure will crush the filter.i don't recommend what I did with the fuel filter. I found out later that it deformed and ended up clogging the inlet. It made it a lot worse. Better to use a proper OCT canister.
You mean the whole filter deformed? I am still running them on my Hyundai and VR, Changed them somewhere last year after a few years of use...loli don't recommend what I did with the fuel filter. I found out later that it deformed and ended up clogging the inlet. It made it a lot worse. Better to use a proper OCT canister.
It's not the vacuum that kills it, it's the heat.Vacuum is too strong. If the filter is always dry then its ok. Once the filter is wet with oil (which it will) this will cause it harder to suck thru the filter and the air will pressure will crush the filter.
This one is pretty damn good! Baffled inside and no irritating indicator which'll leak. Looks expensive - where'd you get this?Ahh..I see. Definitely do not want it to cause more problems than benefits. In that case, do you have any OCT canister to recommend? For MyVI, is something like this good enough?
https://cdn.mishimoto.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/M/M/MMBCC-MSTWO-BK_1_8.png
I guess you got a good one. The ones I used were meltyYou mean the whole filter deformed? I am still running them on my Hyundai and VR, Changed them somewhere last year after a few years of use...lol
The replacement ones also cost like RM5 to 6 only, used a year plus already...I guess you got a good one. The ones I used were melty
Apparently it's a famous brand, Mishimoto. Can get it for around RM70 from Shopee.This one is pretty damn good! Baffled inside and no irritating indicator which'll leak. Looks expensive - where'd you get this?
Erm.. if it's an ori Mishimoto then it wouldn't be RM70 only. But I guess for that price you can't really go wrong since an OCT is just an OCT and doesn't need any fancy bits and bobs to work regardless ori or not. The only different is the mesh filter. With and without tbh isn't that big a difference.Apparently it's a famous brand, Mishimoto. Can get it for around RM70 from Shopee.
https://shopee.com.my/Mishimoto-Com...h-Can-2-Port-Universal-i.108284019.1707143912
I think it's worth the investment as it's only 1 time installation only.
Maybe, In case you want to vent both. There is one going to TB, and another going to inlet manifold. I only vent the one going to TB.....
Overkill much? Now that your engine isn't leaking anymore you shouldn't need so much right?i vent all of it..
-intake manifold sealed
-valve cover breather vented (x4 outlet)
-crankcase breather vented (x2 outlet)
012 495 2116,012 2116867...
