aiyah.. just some typo mistakes.. you know. brain and fingers don't syncho at this time around.. edited.
This is DIY section ler.. not Do It For You section ler.... if you are interested in DIT, come to Seri Kembangan look for "Drex Zhng Kereta Enterprise".. Guan Zhng Kereta is equaly good too! Hahaha!!
u'll need a philips screwdriver... and a "cross" lug nut opener for car tyre...
remove the screw on the horn cover on the bottom(rear part) of the steering... then using the lug nut remover to tighten or loosen the center big nut for the steering... this is for the stock steering dat i have seen a mech done once to my car...
how to take out ur current steering u need to look for urself.. as aftermarket steering may be different from stock..
i think the boss kit still stuck to the steering shaft. you'll need to tap the boss kit out using hammer. try using a rubber coated one..forgot the specific name.
Hi Guys,
Have compile some pictures/visuals of Tyre Brand/Model for your references.
Hope this is helpful for some of you, when we talk about the tyre brand/model......
