>>i install brake pad D.I.Y yesterday<<
reddice
Tochigi Japan
hye all,i hope someone can explain this.
im using satria and yesterday i change my brake pad by myself(D.I.Y),
after all complete,i test the car to do the bedding-in.(rataan lapisan :D )
i drive and brake for maybe 2 kilometres la..not braking so hard...then i come back home and thought everything is ok..BUT..when i touch my break disc,it is hot as hell,even my rims is hot!! :o only the front wheels,both of them..the rear wheels is ok..and there a smell..like something burning..i think maybe because of the break oil that get to the disc...and when i break..the oil burn..maybe la..but the main problem is the heat la..so hot!!like my rim just went back from hell !!
Any opinions?? <_<
u need to bleed ur brake fluid...
when the rims are hot meaning that ur brake is jammed...
that y u smell the burn n felt the heat....
better repair it or u will kill ur clutch plate aka burn ur clutch.. :o
waa!!that bad arr??i already bleed it la...ayyo..maybe the break is jam la...so,how?bleed and all the problem solve?? :(
i tot all disc is hot?
no,only the front disc !!!why does it effect my clutch???
and anyone can teach me how to bleed the right way???PLEASE !!!already done about 3 brake fluid bleeding in 2 week and the money is killing me !!! :blink:
which tyre are hot??
got any diferent on the brake pad dust?
my wira jam brake b4
i change the clipper which is jam and every thing solve!
new brake pad is thicker... so u have to remove some brake oil from de resevoir so dat it wun be too full...
when de pads r new... it new a run-in period... according to instructions.. u need to drive to 60 kmh.. n brake moderately until 20 n repeat for a bout 5-6 times...
dats my experience lar.. others i duno.. :)
already done the run in (bleed-in),i have to remove some break oil?so,no need to bleed anymore??aftre i throw some of the break oil??
the front tyres.both of them !! :(
just look at de resevoir lor. if too full.. use a/some kitchen towel to soak it up... until de correct level...
how many years already your car!
maybe in brake line jam/stuck
after let go the hand brake can the car tyre roll easily??
or u feel like got some thing help u to brake????
after pull the hand break the tyres roll perfectly..but the hand break is locking the rear wheel right?the problem is the front wheel..maybe im wrong..
i mean after let go the handbrake
can all the 4 wheel roll smoothly??
or u feel like one wheel is jam hard to move???
u must feel it ur self
"so hot!!like my rim just went back from hell !!"
from the way your drove your car, maybe your rim did go back to hell :lol:
no,all the wheels roll smoothly..no wheels jam..it goes smooth..no stuck at all..
waa,i think constantine use my car to go to hell la..
if like that then u try to press brake hard and let go and let wheel roll!
feel any diferent??
got any jam??
if no jam
i also cannot help u loh! :lol:
feel any diferent??
got any jam??
that i not try already..later will try...will update tomorrow..brake is the most important that why im so worry..thanks for helping.. :)
dude ,
no need to worry about the brake fluids , now you had installed the brake pads , without turning the piston to check weather its jam'ed up or not and , and you should screw the piston in , so that the pads has clearance to make sure that the pads fit in nicely in the calipers . right now i bet your pistons is on the outwards side , which is pressuring the pads to your disc rotors , which is making your brakes hot & rims hot , when the pads gets hotter it expands and will lock your wheels up .
Originally posted by reddice@Mar 1 2005, 15:42
thank bro,but i dont need to bleed the break?just remove the oil break??
hey bro.. i duno bout this brake thing...
let de experts help... :)
dude ,
man,this is so damn true,yesterday,after i finish work,i open the tyres and see that the brake pad keep pushing the disc..even without breaking..that why the disc is panas like hell !!So what can i do??and the brake piston is damn "keras" la..hard to push in..i push it in and there a gap between the brake pad and the disc..but,when im break again..the gap is lost !!!it stuck !!that why my brake is hot !!
>>outwards?can you explain this vestax ?? i dont want to lock my wheels. :(
