I see some old post asking turbo charge the local SOHC Local 4G92, in proton's.
Below are the original specs that I've found in the net.
Local 4G92, (from the web, didn't remember the site)
Piston size 81mm bore x 77.5 mm stroke
Compression ratio: 10.0:1
4G61T (from 4G61t.com)
Piston size 82mm bore x 75.7.5 mm stroke
Compression ratio: 8.0:1
Does the local 4G92 will fit the 4G61T piston? If not I think oversize of 1mm need to be bored the block. I believe that 4G61T has a stronger piston.
What will be the compression later?
Anyone try this b4?
Anyone try this b4?
).....Its...
