Hi guys.
Just wondering. I find the U12 design quite nice but d only let down its the engine options of either a 1.8 (SR18Di or CA18?) or 2.0 (SR20DE) which has higher fc and road tax, s'more its more or less confirmed tat petrol will b up next yr).
Though tis sounds rather rediculous (i noe ppl would normally up-grade to higher cc or power engines), I was wondering if it is possible/wise to replace the 1.8 with a GA16DE from a halfcut Japan spec B14 (local B13 and B14 dun have d valve timing unit if not mistaken) since both have rather close outputs.
Below are the specifications for both SR18Di and GA16DE. (source: http://english.auto.vl.ru/catalog/nissan)
SR18Di
Displacement, cc: 1838
Engine model: SR18Di
Max.power (Net) kw(PS)/rpm: 110 ps (80.91 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm: 15.3 kg*m (150.04 N*m) / 4000 rpm
Power density: 9.55
Engine type: Water cooling serial 4 cylinder DOHC16 valve
Fuel system: NISSAN Ei (ECCS) electronic gasoline injection
Compression ratio: 9.5
Bore, mm: 82.5
Stroke, mm: 86
Fuel consumption at 10-15 modes, l/100km: 7.3
U12 chasis curb vehicle weight, kg: 1050
GA16DE
Displacement, cc: 1596
Engine model: GA16DE
Max.power (Net), kw(PS)/rpm: 120 ps (88.26 kw) / 6400 rpm
Max.torque(Net), N*m(kg*m)/rpm: 14.8 kg*m (145.14 N*m) / 4400 rpm
Power density: 8.83
Fuel system: NISSAN EGI (NISSAN ECCS)
Compression ratio: 9.9
Bore, mm: 76
Stroke, mm: 88
Fuel consumption at 10-15 modes, l/100km: 6.4
B14 chassis curb vehicle weight, kg: 1060
Hope all d sifus here can help. Thx
SR18Di
Power density: 9.55
Bore, mm: 82.5
Stroke, mm: 86
GA16DE
Power density: 8.83
Bore, mm: 76
Stroke, mm: 88
i think some of the guys from jb in this forum will recognize this car (i should change color,plate,rim...
