http://www.toyota.com/motorsports/ncts/tundra200.html
ENGINE :
Type: Toyota NASCAR V8
Displacement: 358 Cu.
Power: 675 Horsepower at the Rear Wheel
Induction: Normally Aspirated with 390 cfm Carburetor
Bore: 4.185 Inches
Stroke: 3.250 Inches
Compression Ratio: 12.0:1
Engine Design: Toyota Racing Development, (TRD) U.S.A., Inc.
Fuel: Sunoco Racing Gasoline
Fuel Pump: TRD, U.S.A.
Exhaust: TRD U.S.A.
DRIVE TRAIN:
Transmission: 4-Speed Manual
Clutch: Tilton 3-Disc
Final Drive: 9" Ford
CHASSIS/BODY:
Chassis: Steel Tube Frame w/ Safety Roll Cage
Body: Toyota Tundra
Designer: TRD, U.S.A.
Spoiler: 7 Inches, 55 Degree Angle
Steering: Delphi-Saginaw Steering Box
Seating: LaJoie Seating
Hoses and Coolers: C&R, Fluidyne, Goodridge
SUSPENSION
Front: Unequal Length A-Arm
Rear: Trailing Arms with Panhard Rod
Shock Absorbers: Hydraulic, Single Adjustable
WHEELS AND TIRES
Wheels: NASCAR Steel 15 Inches x 9.5 Inches
Tires: Goodyear Wrangler
Brakes: Cast Iron Disc with Multi-Piston Caliper
ADDITIONAL FEATURES
Safety: Five-Point Safety Belts; Window Net; Fire System; Hood, Deck Lid and Spindle Restraint
DIMENSIONS
Race Weight: 3,400 lbs.
Wheel Base: 112 Inches
Overall Length: 206.5 Inches
Overall Width: 80 Inches
Overall Height: 60 Inches
Ground Clearance: 4 inches
Track Width: 60.5 Inches
Fuel Capacity: 22 Gallons
*.......conclusion....hantar tong gas dari KL ke Kangar.........selamba.....tara hal punye...
ENGINE :
Bore: 4.185 Inches
Exhaust: TRD U.S.A.
DRIVE TRAIN:
CHASSIS/BODY:
Body: Toyota Tundra
SUSPENSION
WHEELS AND TIRES
ADDITIONAL FEATURES
DIMENSIONS
..thanx
