4" High-End Titanium PhasePlug MidBass Driver from GERMAN
ICE -In Car Entertainment
lmh77
VISATON Ti100
10 cm (4") High-End Low-Midrange Driver
Pure Titanium cone with Phase Plug
[FONT=&quot]
[/FONT]
[FONT=&quot]- [/FONT]The carefully designed http://www.visaton.com/en/lexikon/C/158.html combines with the shape and material of the http://www.visaton.com/en/lexikon/S/130.html and the adhesives to avoid http://www.visaton.com/en/lexikon/C/158.html resonance.
-The shape of the basket with its large aperture and rear-ventilated damper coupled with the open http://www.visaton.com/en/lexikon/V/128.html with its http://www.visaton.com/en/lexikon/P/159.html produce the lowest possible mechanical losses and produce a correspondingly high mechanical Qfactor.
As a result of the construction using double magnets the TI 100 is also magnetically compensated.
- The TI 100 is ideal as a mid-bass unit in smaller high end shelf speakers or as a mid-range unit in high-end multi-way speakers design.
Technical Data:
Rated power​
40 W​
Maximum power​
60 W​
Nominal impedance Z​
8 Ohm​
Frequency response​
fu–20000 Hz​
(fu: Lower cut-off frequency depending on cabinet)​
Mean sound pressure level​
86 dB (1 W/1 m)​
Angle of sound emmision​
120°/4000 Hz​
Maximum cone displacement​
+/−4 mm​
Resonance frequency fs​
62 Hz​
Magnetic induction​
1,2 T​
Magnetic flux​
300 µWb​
Height of front pole-plate​
4 mm​
Voice coil diameter​
20 mm​
Height of winding​
8,5 mm​
Cutout diameter​
101 mm​
Net weight​
1,05 kg​
D.C. resistance Rdc​
6,0 Ohm​
Mechanical Q factor Qms​
7,05​
Electrical Q factor Qes​
0,40​
Total Q factor Qts​
0,38​
Equivalent volume Vas​
6,9 l​
Effective piston area Sd​
54 cm²​
Dynamically moved mass Mms​
4 g​
Force factor Bxl​
4,8 Tm​
Inductance of the voice coil L​
0,7 mH​
http://www.visaton.com/en/high_end/tiefmittelton/ti100_8.html
4/5 * STAR
Review: Zaph|Audio
Visaton Ti100
Cost: $189
Usability:
Build Quality:
Consistency:
Value:
Comments: Titanium cone midwoofer with a straight cone profile. Very well built but also very expensive. Smooth response with a large breakup node at 6.5kHz. Class leading harmonic distortion from 100-1kHz but rising above that. Low HD along with a low Le point to an excellent motor design. This will sound the best crossed around 1600hz to a large format tweeter, however it could work fine crossed higher depending on your tolerance of the 3rd order HD peak at 1800 hz. Tested July 2007.
PRICE: RM1,200 per pair.
Contact me at:
012-9142998 (Lim)
Excellent 3-Way Set-up in Car from VISATON:
High: G25FFL http://www.visaton.com/en/chassis_zubehoer/ht_kalotten/g25ffl_8.html
Mid: Ti100 http://www.visaton.com/en/chassis_zubehoer/tiefmittelton/ti100_8.html
Bass: GF200 http://www.visaton.com/en/chassis_zubehoer/tiefton/gf200_2x4.html
Cross-Over:
http://www.visaton.com/en/bauvorschlaege/3_wege/classic200_gf/index.html
Excerpt from the review in Hobby HiFi 2/2009 in German
"The most striking characteristic of the Classic GF is the immensely tight, fat and powerful low bass with great attention to detail and a punch that doesn't lose any of its energy even at the lowest frequencies. From double bass to kettledrum the Classic 200 GF provides a convincing bass foundation. The transition from bass to midrange is excellent. Male vocals at around 400 Hz are crystal clear and depicted with enormous precision, revealing clear lines and an exemplary homogeneity. Female vocals too, are realistic. The Depeche Mode classic "Dream On" performed almost hymn-like by the Belgian girl choir Scala conducted by the Kolacny Brothers was met with thunderous applause. Soundtracks with too much presence are unmasked mercilessly. Marla Glen almost sunk her teeth into the microphone when performing "The Cost of Freedom". Mistakes or exaggerations by the recording engineer are revealed ruthlessly. The three-dimensional imaging certainly emphasises on depth. The superficial and almost menacing representation like from some d'Appolito designs is replaced by a certain reservation. The advantage of this spatial interpretation is an amazing depth. In conjunction with an excellent stage width the resulting three-dimensionality is definitely above criticism."
http://www.lautsprecher-shop.de/hifi/index_en.htm?/hifi/classic_200_gf_en.htm
All items available in stock.
Price still can Nego.
TQ.
:itsme:
OFFER ME YOUR REASONABLE PRICE.
:itsme:
TQ
New Stock from German with Price Increased
RM1,300 per pair.
TQ
