works-engineering racing fuel surge tank .
Works
www.worksengineering.co
Petaling Jaya
FUEL SURGE TANK
In racing condition, high lateral G force can cause the fuel to ‘slosh’ around the fuel tank, which can lead to a loss of fuel pressure from the fuel pump and hence causing the engine to run lean and damage it. The fuel surge tank can eliminate this effect, and can also offer the option for running two fuel pumps to ensure there is always constant supply of fuel under all conditions.
Our fuel surge tank is specially designed for street performance which allows you to have increase fuel pump flow capacity and will reduce lean run conditions while doing high lateral G. Our fuel Surge Tank hold up to 5 litres of extra fuel and is made of TIG welded 6061 aluminium.
http://img248.imageshack.us/img248/9057/fuelsurgetankb.jpg
016-733 3353 Chris
016-665 7122 Hua
016-770 7122 An
019-798 8899 Jack
