i think those items in the picture is meant to be installed to standard shocks.. the set comes with sleeving kit(height adjuster), springs.. spring mountings.. etc
means its an adjustable suspension setup on standard abs??...
good for those changed new abs adi and wanted to try on coil-overs... so ur new abs wont go to waste... can use back...
I am using one before, basically it's ok for few months but later the springs becomes soft, u can change it to better springs, harder springs. My mechanic have 2 more sets, Rm500 nego, let me confirm, item in penang
What would be the optimal tyre size for 19x10.5 ie te37? Confused between 275/35 and 275/30. Which one would give less front rubbing on full lock ? Thank you to the big boys here.
