Used Bilsten B14 PSS for Toyota Aristo/Lexus GS300
davidv00
Selangor
Used Bilstein B14 PSS for Toyota Aristo/Lexus GS300
Good Conditions
NO leaks
Original Bilstein B14 PSS
- B14 Performance Suspension Series
- Coilovers
- Front and Rear
- Adjustable Ride Height
SKU: : BIL47-083011
Mfg Part # : 47-083011
All 4 pcs (front and rear)
Brand new price USD1.9k (approx RM8.4k) see https://www.stillen.com/bilstein-lexus-gs300-gs400-gs430-b14-performance-suspension-system-front-and-rear-47-083011.html for proof.
- Threaded body adjustable range of 20 mm at both axles, while installed
- Lowering of approx. 30-50 mm at front and rear
- Road-tested by Bilstein under motor sports conditions and fine-tuned
- Spring plates and lock nuts made from a special aluminum alloy
- Surface coating using Triple-C-Technology® for long-lasting corrosion resistance
- Round threads for ease of adjustment
- Quality sport springs made from highly durable material
- Bilstein gas pressure technology
- Bilstein mono-tube/Upside-Down technology, made in Germany
- German TÜV certificate
Cash on Self Collect only
Re: Used Bilstein B14 PSS for Toyota Aristo/Lexus GS300
Good Conditions
NO leaks
- Coilovers
- Front and Rear
SKU: : BIL47-083011
Is this compatible for Mark X grx120??
I am not sure. You might wanna check with your trusted mechanic.
What is the spring rate ya? Spring looks quite thick there, seems rather stiff/high spring rate, is it? And this one also not yet body shift, is it?
For spring, please refer to the pic below:
If i am not wrong, the spring rate for front is 8kg and rear is 6kg. This short is sport comfort usage.
The spring is progressive style. Sorry i don't have any other information, you can refer to the parts catalogue http://web1.carparts-cat.com/default.aspx?34=0,100370&240=0&32=9563&230=29&10=7201FF5175854AC49DB5A69A54008DE0018004&14=4&12=130
