UNT-1950 Steering Wheel Puller Set
Car Culture
jaspersoong
- A steering wheel puller helps you to remove a steering wheel from your vehicle once you have pulled out the center nut.
- The puller grabs onto the center hub while a screw pushes the steering wheel off the steering column.
- Specialized puller set for steering wheel, pulley and fly wheel puller.
- This is a special tool used for removing steering wheels. It works on most GM, Ford and Chrysler cars.
- It can also be used as a two or three way puller to remove pulleys and flywheel from small engines and snowmobiles.
- Made with the quality and durability to last!
