SUMO Spec R Motor Oil SAE 10W-40 API SM CF
0oo0rock
Selangor
Salam & Hi,
SUMO Spec R Motor Oil SAE Engine Oil 10W40 API SM/CF
** 4 Litres - 1 Tin with only RM85 **
- Universal for gasoline, gas and diesel engines of all types, including multi-valve one, equipped with turbo and catalytic converter.
- Provides reliable protection of engines and is particularly recommended to mixed fleets (cars and trucks)
- Possesses an extended temperature range of application comparing with the traditional mineral oil SAE 10W-40. It guarantees smooth movement at cold start with the temperature below -25'C.
- Based on the level of potential evaporation losses which guarantees a particularly small waste consumption of oil.
- Ideal for engines with the exhaust gas recirculation system (ERG) and is recommended for EURO-3 (2) engines
- Keeps stable protective properties (does not rarefr or thicken), is used in engines with prolonged drain intervals.
Suitable for : Honda,Toyota,Nissan,Mazda,Ford,Proton,Produa,Vtec,Mivec,Blacktop and etc.
*Post can be arrange for other region include Sabah and Sarawak postage cost paid by own.
If interested can call or sms:
Yang 016 229 8316
ok boss,
let me study on the net 1st.
this one u recommending is fully synthetic or semi?
SUMO Spec R Motor Oil SAE 10W-40 is the same as SUMO M2 ultra performance just the packing is different only.it is multigrade mineral oil with performance of the semi-synthetic oil. If u wan any references can check out the official website http://www.sumo-lubricants.com >> product. SUMO SEMI SYNC higher performance one i will post it out by today or soon .
