AMSOIL 10W-40 XL Extended Life Synthetic Motor Oil
Comanche
Banned
Port Klang
Formulated for up to 10,000-miles/six month intervals, or longer when recommended in owners’ manuals or indicated by oil monitoring systems. Provides better wear control, high- and low-temperature protection and increased fuel economy compared to conventional oils.
AMSOIL XL Extended Life Synthetic Motor Oil is designed to provide better wear control, improved high- and low-temperature protection and increased fuel economy compared to conventional oils. AMSOIL XL Synthetic Motor Oil is formulated with extended-drain boost technology. It provides superior performance for up to 10,000-miles/six months, or longer when recommended in owners’ manuals or indicated by electronic oil life monitoring systems.
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API-qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL, the First in Synthetics®, to do the best job protecting your engine.
Extended-Drain Boost Technology
During normal engine operation, the combustion process creates acidic by-products that can lead to internal component corrosion and a reduction in the life expectancy of the engine oil and engine itself. AMSOIL XL Synthetic Motor Oil is formulated with extended-drain boost technology. It employs high-quality synthetic base stocks and a unique additive chemistry to neutralize acids longer than conventional oils. The extra additive package effectively raises the total base number (TBN), a measure of an oil's useful service life, and provides superior protection and performance throughout the entire drain interval.
Lowers Maintenance Costs
Cost-conscious motorists, business owners and fleet managers benefit from the extended drain intervals and wear protection of AMSOIL XL Synthetic Motor Oil. Frequent oil changes are expensive, time-consuming and inconvenient, while longer drain intervals reduce costs and environmental impact. Increased wear control can further reduce maintenance costs. With AMSOIL XL Synthetic Motor Oil, motorists realize the convenience and cost savings of extended drain intervals with maximum engine protection.
Improves Fuel Economy
XL Synthetic Motor Oil is formulated with friction modifiers to reduce friction-related energy loss. It provides better fuel economy compared to conventional, non-fuel-efficient motor oils.
Maintains Low Emissions
AMSOIL XL Synthetic Motor Oil is friendly toward modern emissions control systems, promoting proper operation of catalytic converters for optimum service life and low exhaust emissions.
Protects in All Temperatures
AMSOIL XL is a multi-viscosity formulation. It resists the effects of thermal breakdown, including evaporation and viscosity loss, better than conventional oils while remaining fluid in cold temperatures for easier cold starts and fast startup circulation.
Keeps Engines Clean
AMSOIL XL Synthetic Motor Oil is fortified with detergent and dispersant additives. It is engineered to resist sludge and carbon deposits better than conventional oils. It promotes clean operation for longer-lasting, better-running engines.
Bid Appropriate
AMSOIL XL Synthetic Motor Oil fulfills the requirements of most public and private purchasing bids. It is cost-effective, making it ideal where synthetic motor oil is specified.
APPLICATIONS
AMSOIL XL Synthetic Motor Oil is excellent for use in all types of gasoline-fueled vehicles. It is recommended for all domestic and foreign vehicles requiring any of the following specifications:
XLO 10W-40
API SN, SM…; ACEA A1/B1
COMPATIBILITY
AMSOIL XL Synthetic Motor Oil is compatible with conventional and other synthetic motor oils. Mixing AMSOIL XL Synthetic Motor Oil with other oils, however, will shorten the oil's life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed.
SERVICE LIFE
In gasoline-fueled vehicles, AMSOIL XL Synthetic Motor Oil is recommended for up to 10,000-mile/six-month oil change intervals or longer when recommended in owner’s manuals or indicated by electronic oil life monitoring systems. Change aftermarket, original equipment manufacturer or AMSOIL Ea® Oil Filter at every oil change.
