Squeeky sound when starting the engine
simplythebest
1,500 RPM
Selangor
Got this squeeky sound when starting the engine, the sound goes like this 'ezzzzzzzzzzzzzzzzzz' very sharp noise. What is the problem? :unsure:
maybe u should check the belts? at the pulleys i mean...coz sumtimes when the thing starts to worn out it would squeak when the engine is cold...after 2-3 minutes the squeak is usually gone...
yup.. thats true.. just get the belt to be readjusted and then put some silicon belt dressing..
Thanks dudes, i just got back the workshop to inspect the problem. The mech ask me to change the alternator, air-cond and power steering belts together when I'm planning to change the timing belt, in which another 10,000 kms my timing belt service. He says that I can still drive the car, just that I have to bear with the annoying sound. No harm, true? :rolleyes:
True the squeeky sound only happen in the morning. ;)
i have the same problem.
for my case, it is the aircon belt.
i changed it for RM12, it solved my problem. :rolleyes:
Yes most of the time its the belts problem. Even though they haven't run 10000km yet. Changing them is a good idea since they are cheap. :)
