when my car start it have some ngek ji ngek ji~~ sound.. but if my car run a long way or trip... the sound auto disapear... waht the problem??? the sound from engine area..... any shop can intro??? in KL.. thxx.... must fix the problem!!
when morning start if you heard this kind of noises may be it come from your belt.May be us belt tension not enough or too hard the tension
more info contact me
016-6968391
Stephen
(Mechanical Engineering)
From Sunway Garage
when the is -vacuum it will suck the diaframe to lower down the pressure, full throttle when 0 vacuum most of the stock regulator will rise to 41psi.
how about boost?
will the air pressure push the diaframe down and...
