Soundstream DTower Vertical 4 channel Amp DTR 4.500
ICE -In Car Entertainment
jimmylim85
Tired of the same ol' thing? Like to be different? So do we! Check out the D-Tower amplifiers for something truly revolutionary. When you don't have a lot of floor space to give up, Go Vertical! The DTR1.2200D yields over 2000 watts of power in only 52 square inches. By comparison, our Tarantula TRX2000D takes up 250.8 square inches. You can fit almost FIVE DTR1.2200D amplifiers in the same area. Available in models from 900 to 3400 watts, the Class D's canbe complimented with the DTR4.500 full range 4-channel amplifier. All amplifiers have all of the controls facing rearwards and all of the wiring facing backward, mading installation easy and clean. And for those of you who change your mind a lot, the amplifiers come with an extra set of feet to mount the amplifiers horizontally as well...
FEATURES
• The worlds first vertical automotive stereo amplifier
• Gloss black finish w/ brushed accents
• Double sided pcb w/ smd components
• Aluminum alloy heat-sink
• Regulated mosfet pwm power supply
• Three-way protection circuitry (thermal, short, impedance)
• Delayed on/off circuit
• Variable crossovers (hpf/full/lpf)
• Variable bass boost
• Variable subsonic filter
• Variable phase control
• High level input
• Dash mounted remote gain control
• Direct wire 4 ga. Power, 8 ga. Speaker terminals
• Horiziontal mounting feet included
Technical Specifications:
RMS Power Range : 320-500 Watts
Number Of Channels: 4
Low Frequency response: 10 Hz
High Frequency Response: 220 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features:
Power output:
80 Watts RMS x 4 @ 4 ohms
125 Watts RMS x 4 @ 2 ohms
250 Watts RMS x 2 Bridged @ 4 ohms
aluminum alloy heat-sink
Variable bass boost
High level input
Signal-to-noise ratio: 92dB
Damping factor: >200
Signal voltage: 200mV-5V
Harmonic distortion: 0.50%
Direct wire 4ga. Power 8ga speaker terminal
Dimensions: H: 7.5" x W: 3.375" x L: 15.875"
ORIGINAL from M.A.T with 1 year warranty. Brand new set.
PRICE : RM 1290.00 each
Postage rate : West Malaysia RM 30 / East Malaysia RM 70 (POSLAJU or Skynet)
* Price might change without prior notice due to courier service charges*
How to order?
PM or email me your order model and particulars such as name, mailing address and contact number.
COD takes place only in Ipoh Perak with 50% deposit (non refundable)
Contact number : 012-5356922 / 016-5506922
Email : [email protected]
