Lanzar Optidrive 2000D Monoblock 2000RMS
ICE -In Car Entertainment
Eg Rocks
Brand New Set
specs:
lanzar optidrive 2000d monoblock
700 Watts RMS Power @ 4 Ohms
1100 Watts RMS Power @ 2 Ohms
1600 Watts RMS Power @ 1.3 Ohms
2000 Watts RMS Power @ 0.5 Ohms
4000 Watts Bridge Max Power @ 2 Ohms
Mono Block Subwoofer Amplifier
0.5 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Custom Terminal Block for Speaker Connections
Thermal, Overload Short Protection
Remote Bass Control
Soft Turn On/Off
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to 18dB
Variable Phase Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 6
Dimensions: 10.08'' (W) x 2.12'' (H) x 19.1'' (L)
view(http://www.lanzar.com/itempage.asp?MODEL=OPTI2000D)
CLEARANCE STOCK
RM2200
(price can discuss )
Interested Please Call\Sms me 0167902914
COD JB
