Letting go a set of turbokit for L2 660 turbo. This kit is simply plug and play kit. Kit consist of a reconned hybrid IHI turbo (drag spec) and all the steel braided fitting kit for in and return hoses, front mounted intercooler and whole set of custom stainless steel piping. Last official tested in Sepang drag battle using 1.0bar of boost resulted in mid 15 sec quartermile (I rely solely on the turbo as the rest of the engine is stock). Record can be found in Sepang Drag Battle result page.
Let's rephrase that, this kit will not generate lag at all as the turbo will generate boost from 3k RPM onwards. The intercooler is in mint condition (no crooked fins and no leakage).
Doesnt require additional/larger capacity injectors as I'm with stock L2 injectors. However, for safety purposes if you wanted to boost much higher, a higher capacity fuel pump is advised. Most last recent dyno in GT-Auto in the month of July produced 98hp at the wheels. Result can be found at GT-Auto.
For the stock L2 owner, this is the chance to reduce all the trial and error of trying various turbo setup as this kit is proven and being plug and play reduces all the hassle of modifications to install it. Reason I'm letting this kit go as I'm changing turbo setup for other application (no longer drag).
Some people that have know me or tested with me should know how this turbo setup perform. However I cant bring your for a test now as all my electronics controller was stolen.
Calling for RM1000 for the whole kit one go and not going to be sell separately and will not accept trade-in with other turbo setup. Serious buyer please call 012.2292.130 (Shawn/equinox) to discuss further
