Plug n play coil on plug for 4g93
sukeatila
WTS coil on plug for 4g93 doch na or turbo. plug and play setup
rm 850 nego.
cal danish 0136227026
Why??? Wanna get money.the coil is not relly important to my eng at this moment.
first, this is not 300m's coil. plug gapping is advisable around 0.028" to 0.038.dwell time of coz slightly lower. not really sure but most probably around 3-4ms.how ever this setup connected in series so the timing charge result in half potential. u can wired it parallel if u want it sequential. i believe u require a power transistor replacement.both if it has pro and con. invidual coils charge faster than stock, and less tendancy to fry them up. performance proven.
Is it a plug and play setup? And are these the coils alone or plus holding platE?
b.u.m.p.
---------- Post added at 04:30 PM ---------- 6 hour anti-bump limit - Previous post was at 11:43 AM ----------
it considered as plug n plug.just joint the wire with ur standard connector.coils plus the holding plate..it's better to do some painting on it.
b.u.m.p.
---------- Post added at 01:49 PM ---------- 6 hour anti-bump limit - Previous post was at 09:40 AM ----------
b.u.m.p.
