y dun u test both b4 deciding..im sure the shop let u do that since he know u confirm buying...put 1 set 1st,ask him off the lights..den go on second set.
i'm using blue vision.d old packaging model.no info bout d K's on d box wan.TOTAL CRAP i would say.got no difference compared to d Osram supplied by proton as OEM.i changed 1 side Osram n 1 side BV 2 c d difference but NO DIFFERENCE! :thumpdown damn disappionted.i tot can get at least some whiteness.if wan Philips bulb that can produce white color light, d best i've seen so far is diamond vision.mmg white
i'm using 2 pairs of H1 Diamond vision for my Waja (high & low beam) and 1 pair of H4 for my Kenari. the light looks dimmer but giving a stylish look to my car..... i got it less than RM170 per pair... not so expensive..
Noob question but lets say u have a turbo infront of you with some serial numbers - which series of numbers are you supposed to pick up in order to look up the turbo specifications...
i just changed my car batt into the maintainance-free type 13 plates 70
before this i was using the normal car battery 13 plates 70
i noticed that the rpm drops more when i on my air cond after i changed my batt...
