Hello guys,
Did the ECU check today and found out that there was an error code 18 - TPS narrow range error. Then try to adjust
the tps with the voltmeter but cannot find the spot where only one connector have volts. can only go to this one spot where the TPS start clicking changing the connector voltage from both on or both off.
need some advice on what to do next?
if confirm TPS got problem, where can get one & what the price?
tq
tq
........ definately gonna use this method to adjust.
Thanks.
