k0pi
Hi ZTHians... need some explanation regarding how a Throttle Position Sensor (TPS) relates to Ignition Timing and Fuel Pressure (Fuel Injection).
Having headache trying to figure out matching the setup properly to get smooth running on my 4G92P. Just recently plugged in Works 70mm throttle body and trying out Piper's 286 cams, but having bad jerks when throttle is opened below 5% or below 2000rpm before a go, and I miserably lost all the torque and bhp I had before...
Just to make it easy to focus, these are the 'problems' I couldn't figure out :
1. What happens to Ignition when TPS voltage is increased, and decreased? (current base : TPS = 0% throttle = 0.480v / WOT = 4.265v, Ignition = 12 - running high CR)
2. What happens to Fuel Pressure when TPS voltage is increased, and decreased? (current base FP : 37psi)
3. What happens to Fuel Pressure whe Ignition is increased, or decreased?
I just need to know the relativity between these 3 matters, before sending the car to a tuner (so I could observe and determine the 'tuner' actually know what he's doing... its kinda hard to find a good tuner who sincerely interested tuning a 4G92p these days, so most I observed only go quarter heartedly to tune it, and end up me doing the digging most of the time for refinement). Or maybe I could just understand the relation/concepts and could actually get a good baseline tune before making way to the dyno for AF tuning... or, I am missing out anything important that warns, DON'T DIY.
Tuning tools available : SAFC2, adjustable fuel regulator, timing light.
please help, because it's badly pinging now.
Thanks.
