Ya, Hondata does make tuning ITB alot easier due to the option available to tune via TPS voltage! But still not as simple. Brands like TWM or even TODA uses non-stock honda sensors, so need to do some rewiring then re-calibrate them to Hondata ecu. And all this not many tuners are competent or proven satisfactory to what is want. Idle setting via TPS was told by the matsalleh also very tough. hehe.. But if you got plan to go above NA 300whp on the B-Series, then ITB is really the only way to go.
But on the Omni ITB, i heard there is still some minor issue to make it, fully bolt on and prices they are still trying to make it cheaper than TWM.
ya, 5-zigen i did measure long time ago that it is similar to ITR thats why i went DC 4-1 which about the same size as Mugen 4-1 but cheaper than Mugen. hehe.. Look forward to your results in the 5zigen
Chris which cam you plan to play ?
It's better to leave the TPS within std marking,,,i didnt see any significant improvement when meddling with it. Or perhaps anyone can highlight the benefit here ?:regular_smile:
I never do circuit racing,,,its a matter of preferences. But what i heard ppl look for a cam that give them good midrange just to shoot out of the corner/turn quickly and for the topend,,,,so so is consider ok. It more depends on your driving style,,,if you like holding gear longer at the corner, perhaps top end cam will suits you.
Cp with approx 11.5 compression is good with high cam providing you can dial in ignition closed to maximum, with this setup you will get back the low to mid power. If your head is very good at knocking tolerence,,,low compression + high ignition wont make it knock (must gosok the head a bit) and it wont stall too.
No need to worry with big cams + low comp engine. Do the setup right, dial in the cam right, gosok the head abit,,,you can get power down below with advancing the ignition.
Or if your head is ultra knock tolerence you can play high comp with high cams with high ignition without even knock,,,.
V8_nutter said:Forgot to mention,,,chris you are playing super series right ? meaning in the middle of afternoon,,,those setup cannot do,,,since its for the nighttime setup. Day and night setup is difference,,,you can't play with ignition much especially in the afternoon.
Same thing with cams,,dial in more can do in nighttime,,,but when play afternoon it will knock.
http://www.buddyclub.us/buddyclub/cams/cams_f.html
prolly im getting old, they have spec 6 already from the buddyclub. i noticed the spec it should be good for track and road race purposes. unlike the type5 which has the same similarities like the toda d and meant for super duper high compression engines that has to be overhauled after few races or drags.
chris, the toda C2 looks good to me. the price are fairly cheaper lately compared few months back.
ace79,
wat do u mean by tuning shops?
shops tat sell performance parts or shops tat tune performance cars? haha.....
Great too see a tuning shop fella spilling the beans on his own 2 litre B series setup. Now I hope more tuning shop will understand, the real power made is not from what parts you use, but how you set them up, and most importantly for NA's, what type of work done to the head.
As for me, naaahhhhhhhh. 2 litre Bee is way too expensive for me. I'll stay with a B16A tuning, 180 HPs at the wheel ( well, that's the idea now, since I know what to do, what to fit and where to get it done ), that's good enough for me. Maybe with some fibreglass bodyparts as well, and a custom OEM GB? Heheh.
Looks like u posting in Honda-Tech and ZTH huh...
http://www.honda-tech.com/zerothread/1885263
Why not try the SMSP header that is proven on so many 2liter setups?
Ya, i know they have Spec 6 but my contact in states say that they actually not officially for sale yet. And yes, that spec 6 was suppose to be use for road race engine setup.
I have seen people making good power with the Buddy spec5 and toda d but like i said they all running very high compression to increase the dynamic compression to fit the high overlap. if not, low end suffer like hell.
Toda C2 is indeed at a very good price now!! But my mech is going to let me use foc for the toda c. C2 only has extra 5 degree duration on both side and i feel it won't be a big improvement over the C i can use for free. :regular_smile: If i gonna pay and buy new, i want to spend the money on a much higher cam spec and not 5 degree more than what i have now.
)??? Been interested in this MR2s since I was a kid... hehehe...
