B boolat Known Member Senior Member Joined Apr 12, 2005 Messages 444 Points 3,016 Dec 6, 2009 #1 Comes with 1- Gearbox auto 2- Mounting depan & belakang 3- Wiring sensor 4- ECU takde, kene curik. . . . . can be use at kenari,kelisa,myvi,viva high power K3 N/A engine from storia/duet price nego Attachments K31.JPG 128 KB · Views: 7,663 K32.JPG 168.2 KB · Views: 1,963
J jhoonaun Known Member Senior Member Joined Feb 8, 2009 Messages 170 Points 1,518 Dec 7, 2009 #2 means normal myvi ECU cannot match ?
B boolat Known Member Senior Member Joined Apr 12, 2005 Messages 444 Points 3,016 Dec 7, 2009 #3 jhoonaun said: means normal myvi ECU cannot match ? Click to expand... can match. . .sensor all the same. . .except the throttle body. plug in your myvi throttle body, n ECu, u r ready to smoke. . .
B boolat Known Member Senior Member Joined Apr 12, 2005 Messages 444 Points 3,016 Dec 8, 2009 #4 bump. . . . . .
E et5828 1,500 RPM Senior Member Joined Sep 13, 2004 Messages 1,848 Points 3,138 Dec 17, 2009 #5 normal k3ve and k3ve2 ecu is different. ve2 can rev up will 7.5krpm....normal ecu 6.8k rpm cut
B boolat Known Member Senior Member Joined Apr 12, 2005 Messages 444 Points 3,016 Dec 17, 2009 #6 et5828 said: normal k3ve and k3ve2 ecu is different. ve2 can rev up will 7.5krpm....normal ecu 6.8k rpm cut Click to expand... agreed. . but with 700 rpm different consider how much is power output achieve? and referring to power/torque graph for k3ve2, 6.8krpm-7.5k rpm is already goin down means actually lost power not gain power. . .
