this wan u have to go to jpn ask for the sw20 owner shop than maybe he will tell u....:coffee:
as i know that malaysia got ppl done it b4 cuz when i dl this hot version i ask some ppl that,some of owner sw20/mr2 have done oredi maybe u can find it in ur tt fren gua,hope dis will help u...
thank you for all the sifu response
but how about the handling n power?
does it many difference after the conversion?
any effects to the car chassis n engine response?
the spyder can cope, there are already those who have gone V6 onto MR-S
(V8 in the works!! but lots of customed fabrication)
at most add more bracings.
pro of swap K20a on Spyder
rare, 2.0L, a bit more power over 2zz, lots of honda fans will love you. plz its a K20A!
hp about 190/200whp (engine rated 240hp)
con
expensive swap, everthing after the manifold needs custom fab, requires more then just rewiring(it needs 2 ECU), custom mounts.
like mentioned above, spyder can cope with V6 engines.
in europe a turbo 2zz MR-S is coping with 520whp, he's aiming above 600whp.
I asking for a friend, his currently using a s15 turbo in his fiat coupe, the turbo is going to die soon.. So how much would a good second hand turbo cost, or maybe a brand new.. or any other turbo you guys would...
