this wan u have to go to jpn ask for the sw20 owner shop than maybe he will tell u....:coffee:
as i know that malaysia got ppl done it b4 cuz when i dl this hot version i ask some ppl that,some of owner sw20/mr2 have done oredi maybe u can find it in ur tt fren gua,hope dis will help u...
thank you for all the sifu response
but how about the handling n power?
does it many difference after the conversion?
any effects to the car chassis n engine response?
the spyder can cope, there are already those who have gone V6 onto MR-S
(V8 in the works!! but lots of customed fabrication)
at most add more bracings.
pro of swap K20a on Spyder
rare, 2.0L, a bit more power over 2zz, lots of honda fans will love you. plz its a K20A!
hp about 190/200whp (engine rated 240hp)
con
expensive swap, everthing after the manifold needs custom fab, requires more then just rewiring(it needs 2 ECU), custom mounts.
like mentioned above, spyder can cope with V6 engines.
in europe a turbo 2zz MR-S is coping with 520whp, he's aiming above 600whp.
The Ferrari Owner’s Club Malaysia (FOCM), along with local Ferrari importer Naza Italia, have put their names in the Malaysian Book of Records following the event of...
I've been experienced this problem for few weeks already. My normal idling is around 1k rpm, but sometimes when the engine is getting hot it will hold my rpm at 1500 for 5-10 secs before it's going back to...
after changing to the td04hl-15G... i've been getting this problem :(
my boost will fluctuate from +-0.1bar from full boost so it feels like the car jerking.
i only have a few suspects of my own.
1. fishbone... but...
