K-tuned stainless steel clutch line kit (rhd)
powerautohauz
((( God Level 30,000 RPM )))
K-TUNEDSTAINLESS STEEL CLUTCH LINE KIT (RHD)
Part Number KTD-CLK-RHD
K-TUNED popular Clutch Line Kit is now available slightly longer to fit RHD K-swapped cars perfectly. This fully stainless steel clutch line with SS fittings comes complete with all the adapters needed for both outlet sizes found on oem Honda clutch master cylinders. This way, no matter what master cylinder you have, our clutch line will fit. It also has properly angled fittings on both ends of the hose for a very clean looking install. There is a 180 degree fitting on the master cylinder end and a 90 degree fitting on the slave cylinder end. There will be absolutely no corrosion on this line setup because the hose, adapter fittings, and hose ends are all 100% stainless steel. This is unlike other competitors clutch line kits where the fittings are simply zinc plated.
Applications: EG, DC2, EK (with RHD)
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
