Blox Turbo Oil Inlet
SuperVelocity
5,000 RPM
BLOX TURBO OIL INLET
This kit is flow regulated to prevent bearing cartridge oil seals from blowing out at high oil pressures. The regulator hole is designed with a 1.62mm opening and it can be easily re-drilled with larger hole to increase the oil flow to the turbocharger if necessary. When re-drilling a larger hole, do not exceed 5mm( 7/32 ).
(Universal) complete oil line kit with braided turbo oil drain pipe.
WILL FIT Turbine of: T3, T3T4, T4, T70, T66 , T04B, TO4E, IHI RHC6, T61, T60, GT45, K27 and almost all the turbo chargers (OIL COOLED TURBINE ONLY)
Package Includes:
- Oil restrictor (special designed inlet adapter limits oil flow, effectively prevent blown oil seal caused by excessive oil pressure)
- 1/8" Adapter NPT male fitting that goes to the block and one- 4AN male fitting built on flange. (Made out of Grade 7075 Alum).
- 36" long stainless steel braided line with 3/8 diameter
- comes with gasket, screws/washer
- 17" braided oil drain line
- Heavy duty oil drain adaptors and fittings
- Selling Price RM 150
