ky2004: Our lightweight flywheels are made from Chromoly-Steel (Stronger and lighter than aluminium) and have Zinc Surface Treatment (the best treatment possible for flywheels). You will not be dissapointed with the quality of them.
For testimonials: We are not a sales company. We run our own race teams.
Your cam gears looks very nice.It is adjustable type,rite? Lighter than normal cam gears? Got any for 4G92 mivec? The flywheel is lightened or same weight as original mivec's flywheel?
I'm driving a Proton Gen2..engine code S4PH my gearbox code is F5M41 which is exactly the same gearbox as the 4G18 Mitsu engine with the following ratios ;
F5M41
Gear Ratio 1st
3.583
Gear Ratio 2nd
1.947
Gear Ratio 3rd
1.343
Gear Ratio 4th
0.976
Gear Ratio 5th
0.804
Reverse
3.416
Final Drive
4.052
Can you confirm you Final Drive Ratio for the 4G18 is applicable for the F5M41 tranny? If so, what kind of improvement in performance can I expect also what's the final drive ratio? Can you provide me a full quotation for the following shipped to Singapore for the F5M41 Tranny...Thanks..
Can offset +45 provide sufficient clearance for stock calipers? is it too deep?
Thinking of using this offset for Wira 1.8 with stock calipers...
Say if later change to twin pot calipers, would it also be OK?
im a bit confused here.
do i need a new alarm system for my altezza.
does the standard one have immobilizer installed?
and any good place to install alarm.
any alarm brand for recomendation?
