Hi guys, especially Alvin, because this came out of my mind after seeing you drive, the way you full throttle through the curves and corners, Seeing how your engine rev up.
1st lets decide on the final drive. Since it's the ultimate deciding factor. Always work from end to head. I don't know what you're using, but my guess is 4.3 only. Cause 3rd at near 8k rpm is nearly 140 km/h :) hehehe I think
Anyway, one other thing for me to keep in mind is to design a 5 speed close ratio for you, because I seriously think that's all you'll need to recover the lost of acceleration against the DC5.
Now 4.778 FD is popular, but 4.556 can also be made easily using 41 teeth ring mated to 9 teeth pinion.
It's definitely better than the 4.3 and doesn't loose that much top speed compared to 4.778
Keeping this in mind and setting 5th gear as 1:1
with 4.556 the top speed is 190km/h at 8k rpm using 195/50R15 circumference
with 4.778 it drops to 181 km/h
You can recover the lost of top speed by changing to 60 series equavalent, which makes it
with 4.556 => 200
with 4.778 => 191
So, choose these as you wish.
4.778 comes from 43 teeth ring mated to 9 teeth pinion.
So, now to decide the 5 speed ratios. Using 4.556 as reference for maximum torque / acceleration, compromising top speed to a limit of 191 - instead of 181 using 4.778
1st column T50 TRD close ratio type #1
2nd column max km/h at above input rpm
3rd column Shift up gear and the rpm will drop to
4th column Lost of rpm
2.347 81 5316 2684
1.733 109 5729 2271
1.379 138 5972 2028
1.144 166 6293 1707
1.000 190 8000 0
This design looks promising, but 1st gear acceleration will be completely shit. You can consider not to use it and use the original instead.
The standard T50 ratio are just not relistic for track.
3.587 56 4300 3700
2.022 99 5221 2779
1.384 145 5511 2489
1.000 201 6568 1432
0.861 233 8000 0
revs drop too much :(
OK, lets see what you say :) May be we can sit down and talk later.
with 4.556 => 200
with 4.778 => 191
2.347 81 5316 2684
1.733 109 5729 2271
1.379 138 5972 2028
1.144 166 6293 1707
1.000 190 8000 0
3.587 56 4300 3700
2.022 99 5221 2779
1.384 145 5511 2489
1.000 201 6568 1432
0.861 233 8000 0
Anyone know where can I get the clips from?? I search a few spare part shop in PJ area, they don't have it...
