How your Top Speed at 5th gear
  • Thread starter sincere1
  • Start date
  • Replies 106
  • Views 11K
err.. what if gear 1 - 8500, gear 2nd - 8500, gear 3 - 8500, gear 4 - 8500... gear 5.. 0000.... fking balls went ioff already... suspension wanna tanggal already... hahahah!!! :P
btw sham, adeen car is runing on C56 right? or 160? :P shorter ratio issit.. hehehe!!
at this moment, suspension wont went off except the drive shaft. that all coz heavily in taking corner + bumpy road yet the new bearing which is less than a month broken already. the other bearing OK so far coz it's SKF.
one question, if I put some items in my car which is load about 400-500kg, can any adjustable suspension broke coz of the impact?
my fren using the digital meter, when my speed 180kmh, his digital meter just 150kmh only,
heard my tuner said that digital meter need to be set back then only can reading the speed well.....
The car Pulse Settings Mode was selected correctly during the installation of digital speed meter ?
i.e. Pulse Settings Mode: 2/4/6/8/16/32
my previous svt onli normal gear box....not the c56 wan...
only can go 1st - 7400rpm 2nd - 7400rpm 3rd - 7400rpm 4th - 7400rpm and 5th - manage onli the 6800rpm...
after i changed to using SC....i never thought of trying to get more than just to make the meter sleep at the end of the speedo.....maybe someday i'll try to do it....and try to take a pic....see the SC rpm wan to go how far...
I dont know what kind of gearbox I used. How to recognize it?
hurrmmmmm.....the c56 should be shorter ratio....
better pickup...
the 160 should be better at top end....
don't have any friends using the same engine...?
usually u wouldn't get the c56 gearbox....if i'm not mistaken..
