Originally posted by seanlee+Sep 25 2004, 03:36 -->
QUOTE (seanlee @ Sep 25 2004, 03:36 ) --QuoteBegin-ninja_iga
@Sep 25 2004, 00:48
why do anyone want's to raise the bonnet?
it only lets air from outside in!
not hot air out (at speed)
yes...stan said the rite..in high speed.the cold air will blow in then the hot air out.[/b][/quote] Just for the sake of knowledge and practical discussion. Do correct me if I'm wrong. If my understanding to this case is correct, I believe hot air will come out even at speed. Reasons, air pressure travels high to low, hot to cold... Same reason how our airplanes can fly becos the air travels faster TOP of the aero wings creating lower air presure, at speed, lower than the air BELOW. Thus, higher presure below the wings creating a lift when the plane goes even faster. When the car's engine bay is so hot, and even at speed, typical air flow should flow out instead of going back in becos air pressure traveling outside the engine bay should be lower. Lower air pressure should be more than welcoming to hot air to flow out of the engine bay via the lifted hood. I too find practical application to this theory on some of those CF hood with air vents not scooping air into the engine bay but facing the air flow's direction like the following picture.. http://img.photobucket.com/albums/v77/kingauxs/z_Misc/hood-cf-hyundai-tiburon-0001-turbo1.jpghttp://img.photobucket.com/albums/v77/kingauxs/z_Misc/front_hood_type_r_im.jpg The onli difference I see here is the position of the vents which is mounted in the middle and the shape. For a lifted hood, it's a DIY vent at the back of the hood without the obvious aero shapes of the vents as of the pictures above which helps creating even higher air flow speed. DIY lifted hood may not be as effective as aero shaped cf hood but I still think air will flow out instead. (probably hoping so cos if it works, I'll lift my hood.... cheaper mah.....) Again, correct me if I'm wrong. :) |
