Hi Sifu,
1). From the drawing diagram:-
a. injectors #1 & #2 join into G-Y wire which leads to pin #11 of a-type (26 pin) ECU
b. injectors #3 & #4 join into G-R wire which leads to pin #10 of a-type (26 pin) ECU.
2). The pin #10 is also dubbed as "VSV Fuel Pressure".
Question:-
How to connect the blue wire (injector signal) of Apex'i AVC-R into 4A-GZE ECU since the ECU has two pins connected to the 4 injectors?
Regards.
Question:-
Regards.
