Johnny_9 said:Since we dont know the orginal ignition curve.....is it hit and miss?
RSI said:Tuning ignition timing is best done on the dyno. Without it, the best way is to use an EGT [Exhaust gas temperature] sensor. Overly retarded timing results higher EGT and knocking causes the EGT to surge. So you will want to aim for lowest stable EGT. Normally you would not reach to the knock level as most ECUs have knock sensing that will retard timing as you advance.
Johnny_9 said:So what the best cheap knock meter? Can you make one yourself with a simple electrical DIY knowledge?
Johnny_9 said:Which DYNO?
-Links
-N1
-Amoil
-GT
-Speedworks
-Trial
How good is SAFC2 knock meter?
RSI said:With soldering skills you can make one, here is how to do it.
Buy a big crocodile clip (the ones you use to jumpstart dead car battery. Make a circuit or better still buy a headphone amplifier electronic kit. You can get them from jalan pasar for RM20 or so.
Get an electret condenser microphone and glue it inside the crocodile clip. The mic wires go into the input of the headphone amplifier.
Grip the crocodile clip on a bolt or something gripable under the intake manifold.
Wear headphones while tuning you will be able to clearly hear when engine knocks.
On stock ECUs which mostly have knock sensors. You may hardly hear knock as the ECU will quickly do something when knock occurs. For instanace if you keep reducing the fuel, and knock occurs ECU will start adding fuel up to a point where it does not add anymore. While you keep reducing fuel you will continuosly hear knock and if you don't lift off soon, you have a blown engine. Same goes to ignition timing. Too advance timing can cause knock to occur. The ECU is preprogramed to retard timing up to a certain value. For instance if the ECU is able to retard a maximum of 5 degrees. If you use say e-manage and keep advancing the timing beyond that, there will be a point where ECU won't cure knock anymore. Some even newer ECUs like those Siemens found on late model protons, will attempt to decrease throttle openings to reduce power. This is possible because the throttle is driven by a servo motor which is commanded by the ECU by reading the throttle pedal sensor. On turbo cars such as volvos, the ECU will lower boost as well.
It all depends on the ECU safety strategy.
Knock can sound different from car to car.
It can be:
1. Ting ting ting
2. Kluck kluck kluck
3. chick chick chick
Basically while running there should not be any metallic kind of sound.
Johnny_9 said:..................
How about tapping the voltage signal off the wire from ECU Knock Sensor?
Johnny_9 said:How long does tuning the whole "used portion" ignition table take with a Brake Dyno and e-manage blue?
