- Joined
- Oct 31, 2006
- Messages
- 1,393
- Points
- 1,648
SOLD.
Warranty Terms:-
Item can be warranty with 100% full refund if the item is not in working condition with the following terms.
1.You have to CHOOSE to install it at my workshop in OUG. There will be NO warranty if you collect it and install at other workshop.
2.Once installation done, check for the status of Emanage working/non-working.
3.If working, we're done.
4.If non-working due to the Emanage itself, i will fully refund you. If non-working due to setting/capability/anything that are beyond the emanage+wiring+ignition, there will be non-refundable. Tuning/Setting/Dyno is not provided. Distinguish of setting with the current setting of emanage and your setup that makes your car AFR lean/rich is not in the warranty terms as well.
5.Install workmanship is to be bare by purchaser yourselves.
Warranty Terms:-
