How do I know the amps can blast my Sub or not...
oren
OK... here the specs
which want is better to blast my sub... fyi my sub stat is 1000watts
1.
Output Power 4Ohms - 30W x 2
Output Power 2Ohms - 60W x 2
Output Power Bridged (Mono) - 120W x 1
Distortion Max (4 ohms) - 0.08%
Frequency Response (+/- 0.5dB) - 20Hz - 20kHz
Input Sensitivity (+0dB gain overlap) - 350mV - 6V (low level input) 1V - 13V (high level input)
Bridgeable - Yes
Punch EQ (45 Hz / 20 kHz) - No
Pass-Thru - No
Xcard Qty - 1
2.
: Number of channel 2/1 Channel
: Output power 4Ohms @ Rated THD 2 X 75 Watt
: Output power, driven into 2Ohms 2 X 90 Watt
: Output power Bridge 4Ohms 1 X 150 Watt
: Total harmonic distortion (THD) 0.05%
: Frequency Response 10Hz-50Khz
: Signal to noise Ratio > 80dB
: Channel separation > 75dB
: Variable High pass crossover 60Hz
: Variable Low pass crossover 40-400Hz (12dB per octave)
looks like the second one is able to feed more power if what said is what it performs. Anyway, what sub are u having there? 1000watt? RMS or max? how many coils? what's the impedance. It looks like both amp bridgeable at 4ohms...not sure if it can handle lower impedance than that.
I think you might need more juice for your sub....150W might not make it. Mind listing the model of the sub you have?
here the details...
USED TO PLAY LOUD FOR (SPL) SOUND PRESSURE LEVEL
AND SOUND QUALITY, IT COMES WITH 1000WATTS POWER
HANDLING MAXIMUM PER PIECE , HIGH QUALITY NON PRESS
CONE, POWDER COATED BASKET, 40 OZ MAGNET
STRUCTURE, IMPEDANCE AT 4 OHM, SENSITIVITY AT 90DB,
FREQUENCY RESPONSE AT 25-1.5KHZ
Hehe... what do u think?
Perhaps you can tell us the brand and model and we'll check it out for you.
It's not stated if 1000w is RMS continuous power or peak power. We wouldn't want to BBQ it u know...
Sorry...
I just bought the item from lelong website...
Subwoofer Brand E-Tone 1 pair (I guess it's taiwanese product) it's cost me around RM280 The specs is stated in my previous post...
The amps...
Item No.1 is Rockford Fosgate Model 1998 RF2.6x
Item No.2 is Phasewatts (dunno where its from... Taiwan or Malaysia... hehe...)
Components...
Ecplise Model... can't remember coz had bought it long time ago...
mmm, 1000w is the max power.. feed it abotu 500w max.
Get a good box to fit it in and feed it as much power as u can.
Is the the orange/yellow E-Tone subwoofer...
i saw it once... not remember...
Yes... the sub is in Orange/Black color...
err... want more thing... is it suitable for my components... Eclipse... forgot the model coz has throw away the box and the manual also missing... hehe
i think this subwoofer box has a power rating...
if i happen to go that shop i'll try to see...
500 W would be good enough to thump i presume...more than enough.
Get a proper enclosure made and you should be happy...now you said you have 2 pairs? you looking to have a ported box for them?
Get the Rockford to power up your eclipse components then screw the other amps and get a JBL MONOBLOCK!! :D :D :D :D :D :D 300.1 for simplicity or 500.1 for POWERRR.. *GRoWL* hehehehe
