High performance motorcraft fl- 822 oil filter
Apache91120
Klang
Motorcraft filters are engineered to the high quality standards of the Ford Motor Company and are recommended by Ford as the original equipment replacement filter for Ford, Lincoln and Mercury vehicles. They are designed to help protect against engine wear by screening out abrasives, such as carbon, sand, dust and bits of metal before they can get into your oil. Pressure-relief valves help minimize the chance of contaminated oil circulating back into the engine and also help maintain the supply of oil to the engine under extreme cold conditions or if the filter gets clogged. The outer casings are constructed of steel, “ironed” for a precise fit, painted to resist rust and include flutings to ease removal. The efficient filter media offers increased dirt-collecting capability and ability to capture more engine-harming particles. Silicone anti-drain back valves help prevent oil from draining out of the filter and engine when the engine is not running and resist the aging effects that an engine’s high heat can cause.
Motorcraft Oil Filter is designed to capture engine-harming particles. It is provided with pressure relief valve to maintain the supply of oil to the engine under extreme cold conditions or if the filter gets clogged. This oil filter utilizes anti-drain back valves for high heat resistance and to help prevent dry starts. It has steel cases ironed for a precise fit and painted for resistance to rust. This oil filter facilitates hassle free installation and is backed by a 12 month warranty.
Captures engine harming particles
Provided with anti-drain back valve
12 months warranty
Resistant to rust and heat
Durable
Helps protect against engine wear by screening out abrasives, such as carbon, sand, dust and bits of metal before they can get into your oil
Pressure-relief valves also help maintain the supply of oil to the engine under extreme cold conditions or if the filter gets clogged
Steel cases are "ironed" for a precise fit, fluted to ease removal and painted to resist rust
Efficient filter media offers increased dirt-collecting capability and ability to capture more engine-harming particles
MADE IN USA.
Motorcraft®
Motorcraft® premium parts are the preferred choice of Ford Motor Company. From motor oil to transmission assemblies and everything in between, Motorcraft® parts provide exceptional quality and fit.
Brief History
During the first half of the 1900's, replacement vehicle parts were, by and large, an afterthought for most new vehicle manufacturers and most replacement parts available to owners were produced by aftermarket parts companies. But we wanted to change all that.
Ford Motor Company launched this effort in 1961 by acquiring the well-known and respected Electric Autolite Company, which was already producing numerous replacement parts for Ford vehicles. In 1972, the name was changed to Motorcraft®.
Today, Motorcraft® parts are designed, engineered and recommended by Ford Motor Company for installation on Ford, Lincoln, and Mercury vehicles.
MADE IN USA.
TEL: 012-9154001
