S sitnalm Known Member Senior Member Joined May 6, 2006 Messages 65 Points 1,506 Apr 14, 2012 #1 just to clarify if garrett gt2835r has the same spec as gt3071r? r they the same turbo? thanks
MKMD428 500 RPM Senior Member Joined Aug 21, 2005 Messages 871 Points 5,043 Location johore Apr 14, 2012 #2 err i dont think so..the similarity is only both were ball bearing
Dr.D 500 RPM Senior Member Joined Aug 28, 2005 Messages 522 Points 1,528 Location Petaling Jaya Apr 15, 2012 #3 they are the same. garret just using different code. usually hks whom co venture with garret tend to use the 2835 code. garret on the other hand tend to use 3071. same as hks 3037 same at gt3076r
MKMD428 500 RPM Senior Member Joined Aug 21, 2005 Messages 871 Points 5,043 Location johore Apr 15, 2012 #4 laaa...i thought he was asking both from garret spec. did i misunderstood the q?
S sitnalm Known Member Senior Member Joined May 6, 2006 Messages 65 Points 1,506 Apr 15, 2012 #5 Yes, i was referring to the Garrett GT2835R ... Thanks for your input. Was told it is the same as GT3071R but only the compressor housing is smaller.
S supafly555 Active Member Senior Member Joined Jun 19, 2010 Messages 37 Points 506 Location Kuala Lumpur Apr 29, 2012 #6 all depends on intake housing, turbine housing, inducer, exducer, trim ratio, wastegate...
keisukosan Known Member Senior Member Joined Aug 18, 2006 Messages 316 Points 1,518 May 30, 2012 #7 And have to see what your turbo using on which engine and what mod have you done on your ride ~
TongTurbo Eng From Facebook Joined May 11, 2012 Messages 6 Points 503 May 31, 2012 #8 I believe I have already posted a HKS n Garrett cross reference
S sitnalm Known Member Senior Member Joined May 6, 2006 Messages 65 Points 1,506 May 31, 2012 #9 thanks but was referring to garrett gt2835r, not hks gt2835r.
