hi
Does anyone did the valve tuning on eg9 before? Would it be effect the engine timing? as i m having engine missed and RPM not stabil when idle and reverse RPM reading when on the air-cond. It should be higher when switching on the air-cond but it is lower. If i tune idle controller to lower down the RPM then the ignition will die off when engine is cold. I have done the throttle body cleaning already. Any body can help on this please?
