New in box Dynamat Extreme for sale. Great to absorb the vibrations from the speaker and you music will be more lively.This is not the normal Dynamat.This is the Extreme version.A must for audiophile listeners.
my key hole light got problem doesnt light up ...... bulb is not burnt ..... the problem is no current comming in the bulb socket .... any idea what happen ar ? .......
when you install a VTA External wastegate, do you experience boost creeps ??? as in boost increases as the revs go higher...
Do u need a boost controller to eliminate this...
