As the title suggest, i want to share the job which i did yesterday morning after having my sahur.
Both my front lower arm are worn out and producing this annoying 'tuk tak' sound together with knocking feeling on the steering when going through rough surface. Handing is not as tight as before too. CAr is secured on jackstand throughout the job.
So, lest begin by removing the tyre
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/20140706_065225.jpg
There u go, while on it i do a quick visual check on the pads.Still thick.
3 bolt holding the arm to the subframe and on e bolt holding it to the part behind the disc brake. All size 17.
This is the one behind the disc
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/20140706_065235.jpg
The one in the front part of the subframe
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/20140706_065734.jpg
The 2 bolt on the rear
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/20140706_065716.jpg
As the arm has been on the car for 12 years, a little persuasion is needed. I used a socket extension to drive it out. Be very careful no to damage the driveshaft rubber boot.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/20140706_070102.jpg
Mine has been removed but if yours still refuse to go, knock a flathead screwdriver through the slit at the holding point behind the disc.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/20140706_070303.jpg
My UR lower arm bar was oso removed as it is mounted on the same bolt holding the lower arm.
I dont have the new part pic but here it is mounted on the car.TRW brnd RM 85 a piece.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/IMG-20140706-WA0000.jpg
I took the opportunity to clean my lower arm bar as it was smeared in grease when the right hand driveshaft boot leaks.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/20140706_072300.jpg
Installation is the reverse process of removing.
The drive after was super smooth and quiet. New car feeling. Suspension feel a bit firmer.
However, steering was off center to the left by a quarter turn. Have to redo the allignment then.
. So I was wondering whether anyone out here has the same desire, but just can't find one
