Suck dirty oil. how does ir works?Originally posted by simplythebest@Feb 24 2004, 09:06 AM
me also want to do
the purpose of DIY oil catch tank is to suck all the dirty oil out from the engine right?
what are the items needed? :rolleyes:
Originally posted by Booze+Feb 24 2004, 09:18 AM-->
QUOTE (Booze @ Feb 24 2004, 09:18 AM) --QuoteBegin-simplythebest
me also want to do
Suck dirty oil. how does ir works? then the engine no oil lor :o [/b][/quote] I'm not sure about it too :unsure: maybe only suck the dirty part |
ninja bro....is there any oil that been trapped inside the OCT???...b'coz what..last time i'm also tapped OCT on that side.....but there nothing...la....until i found out what is PCV valve.... :D ...i've done experimental on that hose.....it only splash a small amount of engine oil when u rev....at idling and constant rev...it will suck a small amount of air to the engine rocker cover(engine breather)...just have tested on it....cover the hose with plastic bag...make sure it no leaking....start the engine and c what happen to the plastic bag.....it suck the plastic bag la(venturi effect)...not blow away air...only when u rev abit...the plastic bag will 'kembang' a bit onli.....just have a test on it.....dis'just my 2 cent..bro.... ;)Originally posted by ninja_iga@Feb 24 2004, 06:12 PM
the hose is from the engine block,
located (if you're in front of the car and looking at the engine) at the top left of the engine. If you're using stock airfilter, it should be attached to the airfilter container.. the hose's about 1/2" in diameter.
opening the airfilter cover, you'd see oil stains on the top left (about 10-11 o'clock position since it's a circle) and there's where the oil vapours collect.
i DIY and made my OCT and that kept my engine bay relatively clean after that. No more oily mess except if i fucked up while changing engine oil..
cheers!
try to look on the head cover...there were small hoses isn't???connect to the carb/intake....just try to pull out the hose at the end of it(on head cover side)..leaving the other end hose connect to carb/intake.....then start the engine......put your finger at the end of the hose.....wat happen???can feel isn't.....???the carb/intake creates a vakum pressures isn't???the hose is PCV....every car have this PCV...it was the regulation for the manufacturer....something about enviromental issues........for kancil the different is doesn't have a one way valve la....maybe in the carb......whose know.. ;)Originally posted by ninja_iga@Feb 25 2004, 11:56 AM
Kancil no PCV valve le. (at least that i know of..)
Originally posted by servo+Feb 25 2004, 12:22 PM-->
QUOTE (servo @ Feb 25 2004, 12:22 PM) --QuoteBegin-ninja_iga
try to look on the head cover...there were small hoses isn't???connect to the carb/intake....just try to pull out the hose at the end of it(on head cover side)..leaving the other end hose connect to carb/intake.....then start the engine......put your finger at the end of the hose.....wat happen???can feel isn't.....???the carb/intake creates a vakum pressures isn't???the hose is PCV....every car have this PCV...it was the regulation for the manufacturer....something about enviromental issues........for kancil the different is doesn't have a one way valve la....maybe in the carb......whose know.. ;) [/b][/quote] servo, mine is a 4G15 carb. So i think same as kancil no PCV valve. So can i just summarise your concept to my carb engine ?? My rocket cover hose is currently connected to my air filter box. So if i DIY OCT, then i need to plug the hose that connected to the air box to a filter (can be fuel filter or spare tanki box ? ) then the other end connected back to my air box ?? Correct ?? Plastic won't melted if hold boiled oil ?? What benefit i get after i do it ?? |
